C1 Clock 1959 - NCRS Discussion Boards
C1 Clock 1959
  • John C.
    • September 30, 2001
    • 130
    C1 Clock 1959
    Is there a easy way to remove the clock? Thanks for the help
  • Mark P.
    • May 13, 2008
    • 941
    Re: C1 Clock 1959
    I reach my hand around the back to pull it in about 1/8 of an inch to depress the spring and then turn it counter clockwise ( I think this is the direction but it could be clockwise) about 1/4 inch. It will release and pop forward.
    If you have an original bezel it should be real easy. The repro bezels seem to be slightly bigger and makes it harder to spin.
    • Bruce B.
      • May 31, 1996
      • 2930
      Re: C1 Clock 1959
      All you have to do is push in on the front of the clock from the front and turn it. It will pop out then remove the wire and the light and it's ready to remove.
