In most cases "if it ain't broke don't fix it"....but does this apply to electrical harnesses. During the course of refurbing my '66 bb am replacing the engine/forward lamp, H/L extension, TI harness and TI amp extension as these have seen their best days. The dash harness and rear harnesses appeared to work perfectly (we've heard this before)
except.....when opening either door would "pop" the fuse when lamp circut was engaged. Seems the left courtesy lamp (under dash) is the culprit as I experimented with bulb in either outlet with left side popping the fuse. Issue at bulb outlet?? Should a fix on a 40 + year harness be attempted or cover one's
and replace the harness with new?
Most I know use Lectric Limited but have heard many good things about M & H Electric harness. Am taking hard look at using their stuff. Thanks in advance.
and replace the harness with new? Most I know use Lectric Limited but have heard many good things about M & H Electric harness. Am taking hard look at using their stuff. Thanks in advance.
