"Hot Stuff" Exhaust Manifold Dressing - NCRS Discussion Boards
  • Jamie F.
    • May 20, 2008
    • 337
    Re: "Hot Stuff" Exhaust Manifold Dressing
    When using Hot Stuff I have found that it looks better if you thin it out. It is too thick out of the can.
    • Bill M.
      • 1328
      i let the manifolds get up to operating temperature and then spray Armorall on them. looks great and lasts for months
      • Charles P.
        • April 30, 2005
        • 332
        #18
        For a neat, long lasting appearance I use the Eastwood manifold cast grey. Great long term, low maintenance results. If touch up is needed it WILL match well. It is applied cold and cures when you have bring the car up to operating temp. Of course none of the products listed above including the Eastwood will completely replicate the cast iron look from the factory. I went to a few shows and asked every person whose manifolds looked most correct and came up with my choice. Definitely use in a well vented area or headache will ensue!
        • Valeria H.
          • July 27, 2009
          • 463
          #19
          Bill, what prep did you use prior to your first application of armorAll or did you just spray it on?
          Valeria
          Valeria Hutchinson
          Past Chairman of the Carolinas Chapter
          1960 Roman Red w/ White Coves -"Bella"
          2005 Millennium Yellow 6 speed 400 HP - "Trixie"
          • Ken C.
            • April 28, 2008
            • 58
            #20
            Originally posted by Jack Humphrey (17100)
            Feed your Google search engine with 'Prelube 6' and you should learn all you want to know. Essentially, this is a lubricating product 'rifle shot' at wire rope/cable applications that's designed to sink in and displace moisture...
            Jack, did the google search and retrieved some good information about the Pre Lube 6 product, even found reference to Corvette restorations. Still no link to a supplier north of the Mason Dixon.
            Peter thanks for the link, it appears that unless I can source a similiar product in Canada I will have to import a case.
            Ken
            • Tony S.
              NCRS Vice President, Director Region VII & 10
              • April 30, 1981
              • 990
              #21
              Try this link for Prelube 6 to Quanta Products:
              http://www.quantaproducts.com/search...rt_on=&sort_by=
              Region VII Director (serving members in Arkansas, Kansas, Louisiana, Missouri, Oklahoma and Texas).
              Original member of the Kansas City Chapter, est'd 07/11/1982.
              Member: 1965 and 1966 National Judging Teams
              Judging Chairman--Kansas City Chapter.
              Co-Editor of the 1965 TIM and JG, 6th and 7th editions.
              • Ken C.
                • April 28, 2008
                • 58
                #22
                Anthony, thanks for the link, I was able to order just one can to determine if it really works.
                • Tony S.
                  • April 30, 1981
                  • 990
                  #23
                  Hi Ken. It's all personal taste, but I don't care for the look of painted exhaust manifolds. It just has too much of a customized look to the engine compartment, and I've got more of a factory looking mind set. What I like about the PreLube 6 is that it maintains a rust free look on the exhaust manifolds with a nice fresh cast iron look.
                  Make sure before applying it, you get the manifolds good and clean. I also media blast the rust and gunk off, hang them from a cord and spray them very liberally. Make sure you have something to catch the drips. Give them several days to dry. If you want to give the appearance of orange paint on your manifolds, it's not necessary to paint the whole manifolds even if that's they way it was done at the factory. Why? Because it won't take long for most of the orange paint to burn off anyway. So why not put a litte paint only on those mating areas where the orange paint will survive the burn off? All the judges want to see is some evidence of paint residue on the manifolds anyway.
                  Finally, you will have to maintain your manifolds. Every 4 to 6 months, you should spray more PreLube 6 on the manifolds while they are in place. You don't need to remove them, and the excess will burn off.
                  Try it and see you like it. That's all I use on mine.
                  Best,
                  Tony
                  • Ken C.
                    • April 28, 2008
                    • 58
                    #24
                    Thanks Tony for your advise. I like you lean heavily towards the factory side on both my 79 and 87. Looking forward to some nice looking exhaust manifolds. Thanks again you were a great help.
                    Ken
