Most of the Repro Houses sell a bolt kit that has 4 large flat washers, 4 external teeth sawtooth lockwashers, 2 bright plated bolts and 2 dark coated bolts.
I've searched through the archives and see where it has been noted that one of the bolts (upper passenger) didn't use the sawtooth lockwasher, but a spring lockwasher. I can deal with that, but my question is; why are the sawtooth lockwashers they provide in the kits so big? They Are so much larger than the bolt heads that it really doesn't do any "locking" and look really silly.
Some of the tooth of the lockwasher should be under the head of the bolt in order to provide some locking effect. With these washers, that does not happen and they are basically ornamental.
Are these what was really originally used?
Thanks!
Thanks!
