need help 61 vs. 62 radiator core support - NCRS Discussion Boards
  • Jerry W.
    • January 27, 2009
    • 588
    during current restro....need to replace very tired 62 rad.core support ( w/"x" cross brace )....corvette central has one labeled 1960-1961 for sale....is there any diff. between 61 and 62....adams book says NO...
  • Terry D.
    • May 31, 1987
    • 2691
    Re: need help 61 vs. 62 radiator core support
    Jerry
    I believe the very early 61's are the same as 60. The 61 and 62 are the same. 58-60 are different from what you need. Look at Paragon's listing and you'll see what I mean. Also as a NCRS member you can get a discount.
    • Wayne L.
      • September 30, 1981
      • 233
      If your 62 is either a 340 or 360 hp, the core support will be drilled for the side seal clips. This only applies to 1962 solid lifter engines.
      • Wayne L.
        • 233
        Also, please see page 81 of the judging guide, second sentence of "support seals". In Noland Adam's book, see page 385, upper left hand corner. Also shown in the AIM, sect. 582, sheet 8.00
