Dash pad glue - NCRS Discussion Boards
Dash pad glue
  • Wes S.
    • May 31, 1982
    • 209
    Dash pad glue
    Any recommendations on glue for installing a dash pad in he 62?
  • John F.
    • March 23, 2008
    • 2421
    Re: Dash pad glue
    3M makes many different types.
    • Wes S.
      • May 31, 1982
      • 209
      Re: Dash pad glue
      Any recommedation as to which one is the best for dashpads and the urethane foam backing?
      • Ted K.
        • August 31, 1994
        • 337
        Re: Dash pad glue
        I just used 3m Weather Strip Adhesive the Yellow stuff in the tube. It adhered well and I am assuming it will last. Time will tell.
        Ted
        • Edward L.
          • 278
          Re: Dash pad glue
          The are only a few places at glue will be needed. (speaker bezel, under dash, etc. The dash pad will be held in place by items such as the guage cluster and windshield. If you attempt to glue the entire pad you are asking for trouble in that it will be necessary to fit the pad during the install. After it is in place and secured, glue the areas mentioned before.
