62 Oil Pressure Gauge - NCRS Discussion Boards
  • Wes S.
    • May 31, 1982
    • 209
    I need a little help. How do I remove the tubing nut from the back of the oil pressure gauge. I used a line wrench to remove it, but the shoulders just rounded off. I don't want to trash my oil pressure gauge.
  • Ken A.
    • July 31, 1986
    • 929
    Re: 62 Oil Pressure Gauge
    Vise grips & buy a new fitting/line as needed.
    • Wes S.
      • May 31, 1982
      • 209
      Will mild heating of the nut help?
      • John F.
        • March 23, 2008
        • 2424
        Disconnect the battery while you are in there. Nothing will wake you up faster than bumping a wrench against a hot terminal.
        John
        • Dale S.
          • November 12, 2007
          • 1224
          Use a flare nut wrench next time. I have bent the handles to fit all kinds of situations, like the injector pump on a 1980 Olds diesel. Dale
          • Ken A.
            • July 31, 1986
            • 929
            It will melt the solder sealing the bourdon tube and ruin the gauge
            • Wes S.
              • May 31, 1982
              • 209
              Thank you didn't even think about the solder. Buy the way I am from the south, we interchange flare nut and line wrench regularly.
              • Wayne L.
                • September 30, 1981
                • 233
                I've had the same problem. I removed the gauge from the cluster, clamped the tubing nut in a vise, and rotated the gauge off of the tubing nut by hand. Maybe I was just lucky, but it worked great!
                • Wes S.
                  • May 31, 1982
                  • 209
                  Thanks Wayne I give that a try. Right now its just dangling in midair.
