Need some in depth help on a correct alternator for my 68,anyone with their original? - NCRS Discussion Boards
+ More Options
Posts
  • Brandon T.
    • October 23, 2008
    • 872
    Ok I've done some homework but want to get in depth on this to make sure I match it to my car the best I possibly can to be correct. My 68 is a fairly early 68 built car inside the door jam on the drivers side it is dated D07 I think that means Nov. 7th of 1967? I guess this is the date I match parts up to?
    looks like a correct alternaotr for my 68 427/390 4sp is model number 1100693 which is a 37A model.
    I found one dated 7K2 which I believe says Oct./ 2/ 1967
    is this a good match for my car? an ok match..or a very good match? It would make the alternator dated 1 month and 5 days before the D07 build date of my car in the door jam.
    if it's not perfectly dated for what is most typical, what would be a good date? and I believe you don't count the "I" on electrical components thats why the "K" makes it Oct.
    also is there other ways to see if your car was TI besides the distributor and holes in the fender well, which I have never noticed any holes so I assume mine wasn't TI.
    thanks!
    Re: Need some in depth help on a correct alternator for my 68,anyone with their origi
    Brandon -
    Yup, that'll work just fine for your car.
    • Brandon T.
      • October 23, 2008
      • 872
      Brandon -
      Good deal, hopefuly John pirkle will chime in I may see what he has that matches up, I tried to look him up on here but you need his ID number on top of his name to look him up.
        No, you don't. Just click on the "Members List" item in the blue bar, then click on "J", then go to page 20, and scroll down seven spaces. You look people up by their first name.
        • Brandon T.
          • October 23, 2008
          • 872
          ah! thanks
          • Jack C.
            • September 30, 1992
            • 1090
            John can also fix you up with a voltage regulator if you need one as well.
            Jack Corso
            1972 Elkhart Green LT-1 Coupe 43,200 miles
            Top Flight 1994, 2018 & 2021
            • Brandon T.
              • October 23, 2008
              • 872
              Mine has the original voltage regulator, whether it needs replaced or not I dunno.
              • Jack C.
                • 1090
                See, you did save some money on the restoration.
                Jack Corso
