c2- oil pan - NCRS Discussion Boards
c2- oil pan
  • William G.
    • April 1, 1978
    • 154
    c2- oil pan
    whats correct for a 1965 327/300hp auto,ps
    Some say 4 quarts some say 5 quarts
    will 5 quart pan hit anything under it= ps piston or slave cylinder
  • Chris W.
    • September 30, 1982
    • 49
    Re: c2- oil pan
    Use the correct 4 quart pan. The 5 quart (solid lifter) pan has a longer sump that extends further forward and will interfeer with the Power Steering. The original 4 quart pan is just fine for your engine and was the same pan used for the L79, 350 HP Hydraulic Cam Engine in '65 and worked just fine.
    Chris
    • William G.
      • April 1, 1978
      • 154
      Re: c2- oil pan
      thanks chris
