55 washer pedal - NCRS Discussion Boards
55 washer pedal
  • John S.
    • July 29, 2009
    • 640
    55 washer pedal
    on a 55 V8 where is the location of the plunger -type washer pedal in relation to the later foot pump? what are the differences?
  • Gary C.
    Administrator
    • October 1, 1982
    • 17968
    Re: 55 washer pedal
    John, is it a 6 or V/8? Gary....
    NCRS Texas Chapter
    https://www.ncrstexas.org/
    • Tyler T.
      • August 31, 1981
      • 282
      Re: 55 washer pedal
      I need to know too, mine is a V8.
      Tyler
      • Roy B.
        • February 1, 1975
        • 7044
        Re: 55 washer pedal
        PG foot pump is on the floor, 3 speed foot pump on the fire wall
        • John S.
          • July 29, 2009
          • 640
          Re: 55 washer pedal
          roy, thanks for the picture. the picture shows me where the pedal was located before car #576. at this time i believe the pedal was moved to the cutout you have just to the left and slightly above your emergency lever. washer bags also were added at this time. since many people believe the 3 speeds were at the end of the 55 run it makes sense that the 3 speeds would have this higher mounted pedal. i think this repositioning of the pedal shows that GM at this point in the run had realized it would be installing a good number of 3-speeds.
          • Roy B.
            • February 1, 1975
            • 7044
            Re: 55 washer pedal
            Three speed , pic not so good but the location near Fuse box and steering Column and MB cut out area and cable rout.
            • John S.
              • July 29, 2009
              • 640
              Re: 55 washer pedal
              roy, pictures do not show the foot pedal on the 3-speed. location of foot pedal is more to the left of the emergency brake and further down from the fuse than the pictures taken. if i'm wrong could you point out the foot pump in the picture. your pictures also lead me to ask another question. the hose cap on the washer bottle, is this the one used on 55 or does the cap have a crimped style top like on a pop bottle top?
              • Roy B.
                • February 1, 1975
                • 7044
                Re: 55 washer pedal
                Originally posted by John Scopelite (50653)
                roy, pictures do not show the foot pedal on the 3-speed. location of foot pedal is more to the left of the emergency brake and further down from the fuse than the pictures taken. if i'm wrong could you point out the foot pump in the picture. your pictures also lead me to ask another question. the hose cap on the washer bottle, is this the one used on 55 YES! or does the cap have a crimped style top like on a pop bottle top?
                This is Dave ferguson's 3 speed 55 vett I took
                • Gary C.
                  Administrator
                  • October 1, 1982
                  • 17968
                  Re: 55 washer pedal
                  Photos of Ferg's 55's - 1st is early with floor pump & 2nd is 3 speed with foot pump. Gary....
                  NCRS Texas Chapter
                  • John S.
                    • July 29, 2009
                    • 640
                    Re: 55 washer pedal
                    this last foot pedal is the one i believe was used on powerglide and 3-speeds at approximately #576. as for this pedal being installed on an angle as in the picture i would have doubts. the cars i have seen this pedal on are straight up and down.
