62 fuel gauge & temp gauge wiring - NCRS Discussion Boards
  • John F.
    • March 23, 2008
    • 2424
    I just got this gauge cluster back from D & M Restoration and want to make sure I hook the right colored wires to the correct terminals. Facing the gauge cluster from the driver seat and going Left to Right, is the wire pink-brown, pink-dark blue?
  • Terry D.
    • May 31, 1987
    • 2698
    Re: 62 fuel gauge & temp gauge wiring
    John
    I'm away from home, so I can't look it up for you, but if you have the ST-12 manual, the wiring diagram is pretty easy to read. If not you should get one cause they are a wealth of information.
    • John F.
      • March 23, 2008
      • 2424
      Thanks everyone. Finally all the gauges work. Special thanks to D & M. Fantastic turn around time.
      John
