C1 brake master cylinder adapter - NCRS Discussion Boards
  • Edward M.
    • November 1, 1985
    • 1916
    I am wondering if there is a way to get rid of the brass block that bolts to the end of the brake master cylinder on a C1.
    I was thinking about some sort of fitting that would screw into the end of the master cylinder, and that the brake line (after some careful bending) woiuld screw into.
    I have had some problems getting the brass block to seal completely on my 56, so I am thinking about just eliminating it all together.
    Thoughts?
  • Mike M.
    • May 31, 1974
    • 8382
    Re: C1 brake master cylinder adapter
    renew the pair of brass flat washers. mike
    • Edward M.
      • November 1, 1985
      • 1916
      Did that. Helped, but did not entirely eliminate the issue. I also replaced the brass block with another good (I think it was good) used one. The concentric circles looked fine to me.
      I figure I am going to end up tightening this thing to the point where I strip something out. That is my reasoning for eliminating the brass block.
      Any ideas on how to do this?
