71 leaf spring from Eaton
Re: 71 leaf spring from Eaton
They will strip the spring for you but it will need to be further stripped (blasted) once it arrives. I would save the $75 should they request for removal as at the very least it will protect it somewhat during shipment. As mentioned it comes via UPS with just a sticker and a couple of clamps to hold it together.
I disassembled the spring and tossed the leaf liners that were there. I completely bead blasted the junk they had on it off. Very persistant stuff like a plastized tar was on it. I purchased the Qanta kit along with the liners. It a cinch to finish, very fast drying epoxy like paint that will definitely kill a few brain cells so make sure you apply it in a well ventilated area. I used a whizzer brush. Very nice and did 2 coats.
After the spring was on the ride height was VERY high. I fixed that by using a slightly longer bolt then stock on each side. I drilled the bolts I used to lock the castle nut before I put them on. Good luck- Top
Well now I'm really confused.
"Gray paint", "Gray-Blue Paint", "Coating", "Lubricant", etc.
Sounds like the topic of the leaf spring's color and what is applied to the leaf spring, isn't as cut and dried as we think.
A review of the 1970 - 1972 Corvette Technical Information Manual & Judging Guide (4th Edition - Page 103) indicates that the rear spring is "light gray primer". However, on Page 105, it indicates the rear spring is "primer grey (Hot Rolled)". Is "primer" considered a paint, coating or lubricant or ????
Hmmm....- Top
Hmmm....
Terry and I could likely resolve this in 15 seconds in person.
Just buy the stuff from Quanta and ignore us.
OK, I'll go get the 6 and 3 spring from Eaton ( there about 45 minutes away) Strip the coating off myself. I ordered the paint ( coating) from Quanta, This will be much better than the 6 leaf rusted spring I have now. Thanks again for your help Bob- Top
