69 Tripower ac carb return springs - NCRS Discussion Boards
  • Danny B.
    Infrequent User
    • September 30, 1998
    • 3
    We are having difficulty hooking up the return spring on my 69 tripower a/c car. We are using the correct spring as per various sites, however the spring is getting hung up by the linkage. This keeps the front and rear carbs from operating, Any help, suggestions would be greatly appreciated.
    I have attached a close up.
    Thanks!!
  • Dale S.
    • November 12, 2007
    • 1224
    Re: 69 Tripower ac carb return springs
    Moving you up, maybe you can get an answer. D
    • Jack C.
      • September 30, 1992
      • 1090
      Are you using the additional bracket (Paragon pn#2012) that mounts to the rear carb stud? I have seen where the spring actually mounts in the hole of the acc. bracket.
      Jack Corso
      1972 Elkhart Green LT-1 Coupe 43,200 miles
      Top Flight 1994, 2018 & 2021
      • Danny B.
        Infrequent User
        • 3
        Thanks,I will check this out tonight.
