Garage Door Seals-Bottom and Sides - NCRS Discussion Boards
  • Chuck S.
    • April 1, 1992
    • 4668
    Re: Garage Door Seals-Bottom and Sides
    Thanks Steve. I have been thinking of the 1x2 idea -- it opens up a lot of possibilities. I am leaning to using a rubber strip on the bottom that will sweep along the concrete. The garage is unheated -- so far -- so dust, debris and small animals (as in rodents) are my concerns.
    If there are door stops to keep your doors from swinging inside past the fully closed position, the vinyl flap door stops I mentioned earlier would also work installed on the inside.
    As for the bottom, I think you are on the right track...the best residence door seals consist of several "sweep" fins on the bottom edge of the door, sometimes in conjunction with an adjustable height threshold such that you can adjust the threshold for maximum contact with easy movement and minimum wear.
    Probably the most "sweeps" you would be able to install is one on the front surface and one on the rear surface, just barely touching the floor...too much contact, and the doors will be difficult to open. The problem comes if the floor is irregular or not sloped down away from the threshold. Ideally, you would have a raised threshold in the concrete about an inch high and six inches wide under the doors.
    BTW, Terry, that garage I mentioned with the dirt floor also had a "lock" for the doors...holes crudely hammered through the corrugated door covering for a heavy chain and padlock (sealing out the weather, insects or rodents was not a priority). You had to lift up the bottom corner of the doors about an inch or two before you could move them. Once a modern car was inside the garage, you would have problems exiting. How far we've come.
    • Steven B.
      • June 30, 1982
      • 4005
      Terry, we had thought about "gluing" a 1" X 2" strip and weatherstrip on the floor to meet the back of the doors but didn't. It might work. It may also work to attach the strip and weatherstrip (round channel) to the backside of the doors. That is probably the better idea.
      Since I got the snake I don't worry as much about rodents.
      Steve
      • Dale S.
        • November 12, 2007
        • 1224
        #18
        Steve, how about Tom McEwen the "Mongoose". D
        • Steven B.
          • June 30, 1982
          • 4005
          #19
          Dale, he could take care of "The Snake" for me!
            • 15625
            #20
            If I were to get a "pet" I would lean toward getting a cat, but I actually don't have a rodent problem in the garage, yet. I am looking toward pervention. The house is another story, but the rodents there only bother the girls.
            • Harmon C.
              • August 31, 1994
              • 3228
              #21
              First you seal the doors up real good and the next post is how to stop the gas smell from staying in the garage when you park the hot car. Is their any end to this circle.
              Lyle
