1966 M-22/HD 427 help - NCRS Discussion Boards
  • Peter G.
    • September 30, 1992
    • 135
    Does anyone have information about the number of '66 M-22/427 combos are out there? Also, if anyone has noted any differences in the internals of the HD427s vs. the 427/425 if they had the opportunity to do the documentation and rebuild themselves? I've seen a few M-22 equipped 427 '66s over the years, but never had the opportunity to check internally.
    Dr. Pete
    www.CorvetteLegends.com
  • Wayne M.
    • March 1, 1980
    • 6414
    Re: 1966 M-22/HD 427 help
    Peter --- I'm sure you're aware of the 1966MY M22 production figures quoted by A. Colvin and (in the case of Corvettes, confirmed by Noland's Vol 2).
    That is: Passenger 2; Chevelle 12; Corvette 15.
    I would assume that all these ended up in big blocks, if not entirely hooked up to 427's.
    I'm a bit confused; by your "internals of the HD427". Are you referring to the M22 trans or the early L88-equivalent engine assemblies ? Could you be more specific ?
    • Peter G.
      • 135
      Wayne, I am trying to see how many M-22s were bolted up to the HD427s, and if internal parts such as the camshaft, are different from the regular production L-72 427/425s as well.
      Dr. Pete
      • Clem Z.
        • January 1, 2006
        • 9427
        the cam part #3879605
          Al Grenning (with others) has researched this issue in detail, and made a presentation on it in his November, 2008 seminar at Pro Team, and at several other locations since then.
          • Clem Z.
            • January 1, 2006
            • 9427
            the 12.5/1 piston #3879928
            • Peter G.
              • 135
              So is it safe to assume that all the M-22 cars are HD427s?
              Dr. Pete
              • Clem Z.
                • January 1, 2006
                • 9427
                i would say that all HD-427 had the M-22 but not all M-22 equipted cars were HD-427. JMHO
                • Peter G.
                  • 135
                  That was my understanding too. Just wanted to double check with you guys.
                  Dr. Pete
                  • Michael H.
                    • January 29, 2008
                    • 7477
                    I'm not exactly sure what you are looking for, Peter. What internal engine components would have been different if an M22 was ordered with an L72 425 HP?
                    • Tom M.
                      • 716
                      Kevin Mackay is the man to talk about this
