Thermostat Gasket - NCRS Discussion Boards
Thermostat Gasket
  • Pierre J.
    • July 31, 2000
    • 193
    Thermostat Gasket
    A while back I bought, from a GM dealer, a thermostat gasket that had a bead of silicone on both sides around the opening. I somehow misplaced the part number and I am looking at purchasing this gasket again. Would anyone have the part number for this gasket?
    Pierre
    Re: Thermostat Gasket
    Pierre -
    It's #10105135. Great gasket, can't be told from the original when installed, won't leak.
    • Pierre J.
      • July 31, 2000
      • 193
      Pierre -
      Thanks John, much appreciated.
      Pierre
        • 11678
        I gotta believe that someone else makes the gasket and it can be purchased for less somewhere other than the usual greedy GM parts man?
        Or is it a GM-only item?
        Patrick
        • Dale S.
          • November 12, 2007
          • 1224
          Fel pro used to make one like that. Not sure it was exactly the same. Dale
          • John D.
            • December 1, 1979
            • 5507
            A job I don't like but do anyhow is to lap the thermostat housings flat as they are typically warped, etc.
            Use a granite surface plate and various grades of sandpaper till your arm gets sore. Do NOT use a belt sander.
            Then you can go to your local Car Quest store and buy a really nice original looking gasket cheap. C25930. I buy them in packs of 10 and use them exclusively on all FI jobs. Never had a thermostat area leak. Gasket is sticky on one side.
            Not fun sanding cast iron 'stat covers but a necessary evil. Just installed an original 'stat cover on a 63 Fi and couldn't believe how bad it was eaten and warped.
            • Clem Z.
              • January 1, 2006
              • 9427
              if they are realy bad why don't you have a machine shop fly cut them flat ?
                Fel-Pro still makes them, but they're blue molded plastic about 1/8" thick and look ugly when installed. The GM gasket is brownish thick paper with a circular silicone bead seal molded on both sides, and looks perfectly ordinary when installed. They come in packs of ten.
                • Steven B.
                  • June 30, 1982
                  • 4002
                  Do the GM gaskets look correct for all years (especially '57, '77, 78)?
                  'Remember when the gasket was free with a thermostat? My parts guy, and neighbor, used to give me 2 or 3 when I got a new thermostat.
                  Steve
                    Do the GM gaskets look correct for all years (especially '57, '77, 78)?Steve
                    As far as I know, yes - they've used that same gasket pattern for decades.
                    • Steven B.
                      • June 30, 1982
                      • 4002
                      Thanks John! 'Always appreciated.
                      Steve
