57 Body Mount Pads - NCRS Discussion Boards
57 Body Mount Pads
  • Tom H.
    • July 30, 2008
    • 49
    57 Body Mount Pads
    My assembly manual (seems to) show 7 body mount pad locations, 1 under each seat, 4 at the back end of the X and 1 in the middle under the spare tire well.
    My replacement set contains 8 pads. Where does #8 go?
  • Gary C.
    Administrator
    • October 1, 1982
    • 17771
    Re: 57 Body Mount Pads
    Tom, you may need more than one in a location. Couple of mine were stacked. Photo on my '57 from original their original positions and quantity. Also, very very late used cushions instead of the round doughnuts for the far rear body mounts. Gary....
    NCRS Texas Chapter
    https://www.ncrstexas.org/
    • Tom H.
      • July 30, 2008
      • 49
      Thanks Gary,
      I should have guessed that each floor is a little different.
      • Jim H.
        • April 1, 2002
        • 112
        What type of adhesive do you use to put the cushions onto the frame?
        • Gary C.
          Administrator
          • October 1, 1982
          • 17771
          Jim, used black weatherstrip adhesive to tack them in place. Any black adhesive would probably work. Gary....
          NCRS Texas Chapter
          • Brian W.
            • September 30, 1990
            • 216
            If the shim pads you are referring to are part #3706913 in Sec. 1, Sheet 1 of the Assembly Manual? Look at Sec. 13, Sheet 2 at the top of the page under the fan shroud shows shim #3706913 with cement. If I'm reading this right, that's where I put mine.
            Brian
            • Barry H.
              • April 30, 1976
              • 213
              Jim, GM used an asphalt based adhesive to hold the pads in place. I usually get a caulking tube of cheap asphalt based roof cement, this can also be used for sealing the black rubber wiring grommets to the firewall. Looks good, can be cleaned with kerosene, & seals out water & noise. Barry Holmes #940
