66 L79 Pulley Question - NCRS Discussion Boards
  • Todd H.
    • April 30, 2002
    • 22
    After reading and searching several posts...I am still confussed.
    I am rebuiling a 66 L79 with no P/S or Air or Brakes. Just a base L79.
    My question is....what is the proper water pump and balancer pulley for a non power car.
    My logic says single groove buy after looking at catalogs and reading...things are pointing to a two groove harmonic pulley.
    Can someone shed some light and direct me to the correct setup for my car?
  • Timothy B.
    • April 30, 1983
    • 5203
    Re: 66 L79 Pulley Question
    Todd, Check out this picture that was posted a few days ago. This is a 1966 L-79 and clearly shows two groove pulleys and the location of the dedicated water pump/crankshaft non adjustable belt.
    • Jack H.
      • April 1, 1990
      • 9906
      Characteristics of the factory correct/original water pump should be called out in your copy of the '66 JG book...
      • Michael H.
        • January 29, 2008
        • 7477
        I agree with Tim. There was quite a debate about this belt and pulley setup for 66 L79 here a few years ago. In the end, most everyone agreed that these engines had deep groove double pulleys with the C/shaft-W/Pump belt in the rear groove.
        • Bill I.
          • January 29, 2008
          • 554
          Todd also consider the advantage with a 2 groove if you lose the alt belt, at least you'll get home without the car overheating. Bill
          • Peter J.
            • September 30, 1994
            • 586
            L-79 Water pump pulley # 3770245 (7-1/8") deep grove. They are on ebay fairly often. This is a twin belt one for alternator-crank-water pump and one captured for crank and water pump.
            • Bob E.
              Infrequent User
              • March 1, 1995
              • 20
              There is a very good 1966 small-block pulley article in the spring 2009 NCRS Restorer. It explains in depth with photos and part numbers.
              Bob
              • Peter J.
                • 586
                Bob is right about that article, members - Mark Gorney & Jim Williams answered every question one could ask about pulley aplications on a 327 Corvette built in 1966. They cover everything from part number, size and number of belts. I have been gathering parts for a spare engine for my 66 L-79 and found there artilce answered every question I had about correct pulleys.
                • Peter J.
                  • 586
                  Michael,
                  I remember that debate. I always wondered how that got started. I am the second owner of a 66 L-79 with the captured belt and I know the original owner didn't monkey with this car at all and every base L-79 I ever judged had the same configuration. Then out of the blue comes this single belt theory. Makes me wonder what will be in the new super duper 66 JG.
                  Pete
                  • Greg T.
                    • January 1, 2004
                    • 136
                    I've never seen a no power L79 line up their alternator belt using the outer groove. You can't argue the picture but if you've ever had a L79 with the alternator running off the outer groove I'd like to see it.
                    • Peter J.
                      • 586
                      Greg you are right my outer belt is the water pump/crank. Inner belt: water pump/crank/alternator.
                      • Todd H.
                        • April 30, 2002
                        • 22
                        Guys...thanks so much for the direction. Things are getting close. I am putting the body on this Sunday....wish me luck.2009-07-31DSC_00401.JPG
                          Greg -
                          Interesting observation - the photo (taken on the line at St. Louis) shows the captive belt on the rearward groove, but every photo I have in my files of base '66 L-79's shows the captive belt on the forward groove and the WP/Crank/Alt belt on the rearward groove.
                          • Kenneth F.
                            • September 30, 1988
                            • 285
                            I have a 1966, 350HP, no options car, I have owned since 1967. The car is mostly untouched. with 44K and the captive belt is forward, the rear belt connects water pump, crankshaft, and the alternator.
                            • Patrick T.
                              • September 30, 1999
                              • 1286
                              Greg -
                              Agreed, I have a '67 no power L-79 with the correct pulleys and the alternator belt must go on rear groove and the captive belt on the outer groove. I think '66 and '67 are the same. Everyone tells me this is wrong but here is a photo from Noland Adams Vol. II with the captive belt on the outside groove. PT
