1963 Rear End Differential casing - NCRS Discussion Boards
  • Gerald C.
    • June 30, 1987
    • 1314
    Does any one have any good sources for this piece. I need it for my May 14, 1963 car with a 3:36 (CB) ratio.
    I have a 1964 rear end that has just been re-done and I'm looking to switch the internals into the correct casing.
    Any advice would be appreciated.
    Jerry
  • Harry S.
    • July 31, 2002
    • 5349
    Re: 1963 Rear End Differential casing
    Jerry, they are hard to find and when you do they are expensive. My April 20th 63 car has an April 10th build date with a 3.36. CB 4 10 63
    Saying that a 5 4 63 stamp is probably the youngest one to start looking for. You can go back six months.
    Places to look, try Pat Ikerd. He has an extensive supply in stock. Here is one of his ebay auctions:
    Since Carlisle is coming up, if your there, probably better deals available. Also try ebay for complete rears, just tear it down and use the case and resell the rest.
    • Bob R.
      • June 30, 2002
      • 1596
      My 63 was also built on May 14th. My rear differential is CJ 5 2 63. If this info helps
