What part is this? (67) - NCRS Discussion Boards
  • Chris E.
    • November 3, 2006
    • 1336
    Chris Enstrom
    2011 Z06, red/red
  • Ken A.
    • July 31, 1986
    • 929
    Re: What part is this? (67)
    Originally posted by Chris Enstrom (46481)
    Looks like a quarter an assembly line worker dropped for you to buy a gallon of gas with. That other thing, the wingnut, ain't part of a Corvette.
    • Chris E.
      • November 3, 2006
      • 1336
      I had a vague memory when I took the car apart that I had an original 67 327/350 horse air cleaner wing nut. This is THE only wing nut I can find. Believe me, I turned the garage upside down.......
      Chris Enstrom
      2011 Z06, red/red
      • Gerard F.
        • June 30, 2004
        • 3806
        Chris,
        Look in the bottom of the toolbox you were using when you took the car apart.
        That's where I found my original top ignition shield bolt for my 67, after 20 years with a wingbolt in its place.
        Jerry Fuccillo
        • Chris E.
          • November 3, 2006
          • 1336
          Originally posted by Gerard Fuccillo (42179)
          Chris,
          Jerry, I'll check that, but I've already almost completely turned the garage insight out. Me and the Mrs. were in the garage until 10 pm last night pulling stuff of shelves....
          Chris Enstrom
          2011 Z06, red/red
          • Ron N.
            • August 18, 2008
            • 243
            Chris, here is the original wing nut from my air cleaner cover (67 original owver).
            Ron
            • Ron N.
              • August 18, 2008
              • 243
              Chris, another view.
              Ron
                • May 31, 1974
                • 8409
                looks like a late c-1 dual four aircleaner wingnut. mike
                • Gerard F.
                  • June 30, 2004
                  • 3806
                  Mike,
                  Same wingnut on my 82 El Camino V6. Must be a very common GM part.
                  Jerry Fuccillo
                  • Brant H.
                    • March 1, 1987
                    • 45
                    It's definitely an air cleaner wing nut for a '60's V8 Ford. It may have been on some Chevrolets too, don't know.
                    • Harry S.
                      • July 31, 2002
                      • 5349
                      Mike, I agree, that's what I recall being there.
                      • Patrick T.
                        • September 30, 1999
                        • 1286
                        I've heard if the air cleaner wing nut is thick as a nickel, it's real. If it's thick as a dime, it's a repop.
                        • Steven B.
                          • June 30, 1982
                          • 4018
                          That is the same style wingnut that was on my radial arm saw when new. 'Got one of those in the garage missing a fastener?
                          • Chris E.
                            • November 3, 2006
                            • 1336
                            Nope, no radial arm saw here. Just one lonely 67 L79 air cleaner assembly, with no wing nut.
                            Chris Enstrom
                            2011 Z06, red/red
                            • Gene M.
                              • April 1, 1985
                              • 4233
                              The item on the left is a quarter, Unites States Currency worth 25 cents. Buying power is somewhat less........
