ok guys got the pilot bearing in and flywheel on question tho - NCRS Discussion Boards
  • Brandon T.
    • October 23, 2008
    • 872
    Like I said I have the flywheel on and torqued to 60ft lbs..I used the grease method to get the old pilot bearing out..worked great!
    watched this video http://www.youtube.com/watch?v=qFXhTR-epws
    however, at 7:12 into the video is that correct to grease that? or would that just collect grit and cause problems?
  • Terry D.
    • May 31, 1987
    • 2692
    Re: ok guys got the pilot bearing in and flywheel on question tho
    Brandon
    Instead of asking people to wtch a 7 min video why don't you just describe what it shows, then maybe someone will answer
    • Brandon T.
      • October 23, 2008
      • 872
      Originally posted by Terry Deusterman (11486)
      Brandon
      I can do that but if you fast forward to 7:12 into the video you will see what he is greasing.
      might be better than me explaning since I'm certainly no mechanic.
      • Ralph P.
        • February 1, 1990
        • 253
        Terry, be careful of using any heavy lube or grease on the shaft.... it can cause the disc to bind & you'll be pulling the trans again ( my bitter experience ! ) ... also, be sure you have a REAL pilot bearing... if it's magnetic, it's NOT . Many clutch kits contain an iron knockoff instead of the correct oiled bronze . Very little , if any, lube is needed .
        • Jim O.
          • January 3, 2007
          • 11
          "Lubriplate" is a great all around lubricant. Use a reasonable amount in the pilot bearing and on the nose of the input shaft. I would brush it on the input shaft splines to ensure they are coated uniformly and not too thick.
