C3 clutch pedal assembly - NCRS Discussion Boards
  • Joseph C.
    • April 1, 2006
    • 48
    Early 68 restoring clutch, gas peddle assembly. What type of black is everything. Thanks for the help.
    • 43297
    Re: C3 clutch pedal assembly
    Joseph----
    The clutch pedal and brake pedal are painted semi-gloss black. For 1968 I believe the accelerator linkage is a 2 piece assembly. The lower rod is natural steel. The upper part of the assembly is a fabricated steel lever. I just don't recall if this is natural steel or if it's painted semi-gloss black. I think it's natural but I'm not sure.
    The pedal pads for both the brake and clutch are the same and are black rubber. There is a polished stainless steel trim surrounding the pad.
    The accelerator pedal is some sort of more-or-less hard black plastic. It also has a stainless steel trim.
    • Joseph C.
      • April 1, 2006
      • 48
      Thanks It looks semi gloss. It appears as if they were dipped. The tops look natural.
        That's correct - they were dipped to an inch or two short of the pivot tubes at the top so the bushings would fit.
