I know you're going to say this can't be, but here goes:
My 1972 LT1 w/ac has press-in rocker studs and 2.02"/1.60" intake/exhaust valves. With the exception of a few individuals they all say 70-72 LT1 came with screw-in rocker studs, guide plates and 2.02"/1.60" valves. Other say this was the case with late 1972 model year LT1's.
All the pertinent casting #'s and date codes are right on and within the date code tolerances. See the following:
Vehicle Identification Number: 1Z37L2S523822
1 = Chevrolet Division
Z = Corvette
37 = Coupe
L = LT1 engine
2 = 1972
S = St. Louis plant assembly
523822 = Production sequence number (during the month of May 1972 Corvette units 22611 through 25225 were produced)
Trim Tag:
Body - K14 = Built June 14, 1972
Trim - 400 = Vinyl black
Color - 912 = Sunflower yellow
Engine Stamp Pad:
V0421CKY 12S523822
V = Flint Plant
0421 - Date Code = April 21 (engine assembly date)
CKY = 4 speed, mechanical lifters, Holley 4BBL
12S523822 - 1 = Chevrolet, 2 = 1972, S = St Louis, 523822 = production sequence number
Block:
3970010 - 4 bolt main
Date code: D82 - D = April, 8 = 8th day, 2 = 1972
Transmission:
VIN (Vehicle Identification Number): L2S523822
Main case part number: 3925661
Extension (tail) part number: 3978764
Side cover part number: 3952648
Code: P2E19A
P = Muncie 4-speed
2 = 1972
E19 = May 19th
A = 2.52:1 - First gear - wide ratio
Rear:
AAW143 1E
AA = 3.55:1 Corvette positraction axle
W = Warren, MI plant
143 = Day of year: May 22, 1972
1 = Shift
E = Positraction Source: Eaton
Alternator:
11 00544 61 - 1972 Delcotron 61 Amp Alternator - with A/C
12VNEG = 12 Volt - negative ground
Date Code: 2E17 - 2 = 1972, E = May, 17 = 17TH day
Carburetor:
Holley 4150 - with standard transmission
Carb list # R 6239-1
Date Code: 244 - 2 = 1972, 4 = April, 4 = 4th Week
Starter:
1108418 - 1972 Corvette 350/255HP with manual transmission
Date Code: 2D26 - 2 = 1972, D = April, 26 = 26th day
Intake Manifold:
3959594 -1972 Corvette 350/255HP
(note: date code is under the oil splash shield on the under side of the manifold. The shield, if removed will be damaged.
Exhaust Manifolds:
Front side:
Left - 3932461, RH6
Right - 3932461, RH6
Back side:
Left - date code: E17 - E = May, 17 = 17th day
Right - date code: E12 - E = May, 12 = 12th day
Distributor:
1112101 - 350/255HP / LT1
Date Code: 2E18 - 2 = 1972, E = May, 18 = 18th day
Heads:
3973487X - This head is identical to 397387. The 3973487X was used only on late 1972 models.
Date Code: Left - C62 - C = March, 6 = 6th day, 2 = 1972
Date Code: Right - C142 - C = March, 14 =14th day, 2 = 1972
Value Covers:
Left hand - 3989005
Right hand - 3965542
Master Cylinder:
5480346
Stamping on flat ground area: PG
Seat Belts:
Driver & passenger lap belt - model C-15
Date Code: 1-E-72 - 1 = week, E = day (Friday), 72 = 1972
Driver & passenger shoulder belt - model C-25
Date Code 1-F-72 - 1 = week, F = day (Saturday), 72 = 1972
Wheels:
K 1 3 3 (v)*1 AZ -------------- K 1 2 5 (v)* 1 7 AZ (spare)
K = Kelsey Hayes ------------- K = Kelsey Hayes
1 = Romulus Plant ------------ 1 = Romulus Plant
3 = 1973 ------------------------- 2 = 1972 (spare)
3 = March ------------------------5 = May
1 = 1st day -----------------------17 = 17th day
AZ = Corvette (15X8) -------- AZ = Corvette (15X8)
* (v = valve stem hole)
LOF Glass:
Left side:
Soft-Ray
Safety AS2
Solid tempered
DOT 15
M74
Flo-lite
Dated Code: JY = May 1972
Right side:
Soft-Ray
Safety AS2
Solid tempered
DOT 15
M54
Flo-lite
Windshield:
Shaded
Soft-Ray
Safety AS1
Laminated
DOT 15
M24
Flo-lite
Windshield
Date Code: IY = June 1972
I have also attached a couple pictures of one of the heads showing the valve train and one of the valves with mic showing the size of the intake valve.
I know this is long and spread out, but I would like to get some feed back from others. I have been emailing back and forth with Joe Lucia and we concluded the heads are an aberration. Given the dates and casting numbers I am confident the heads are original the car.
Your comments.
Z = Corvette
37 = Coupe
L = LT1 engine
2 = 1972
Trim Tag:
Engine Stamp Pad:
V0421CKY 12S523822
V = Flint Plant
Block:
Transmission:
Code: P2E19A
P = Muncie 4-speed
2 = 1972
E19 = May 19th
Rear:
AAW143 1E
1 = Shift
Alternator:
Carburetor:
Starter:
Intake Manifold:
Exhaust Manifolds:
Front side:
Left - 3932461, RH6
Back side:
Distributor:
Heads:
Value Covers:
Left hand - 3989005
Master Cylinder:
5480346
Seat Belts:
Wheels:
LOF Glass:
Left side:
Soft-Ray
Safety AS2
Solid tempered
DOT 15
M74
Flo-lite
Right side:
Soft-Ray
Safety AS2
Solid tempered
DOT 15
M54
Flo-lite
Windshield:
Shaded
Soft-Ray
Safety AS1
Laminated
DOT 15
M24
Flo-lite
Windshield
Your comments.
