I finally got the trip odometer reset cable out it is easier if you disconnect the Tach Cable. Trying to disconnect the Speedometer cable pushing on the tab in the back, but it won't come off. Attempted to install the new cable I got from Par---- but it does not go in to the back of the Speedometer and the nut does not touch the housing, compared the old cable to the new one and the brass retainer on the end of the cable is larger on the replacement? So I lube the original cable and attempted to reinstall, but I can't get the nut started into the speedometer. It will not touch the base, I'm I doing something wrong, any tips?
