1968 Corvette antenna and ground - NCRS Discussion Boards
  • D S.
    • March 1, 2005
    • 1551
    Did the 1968 Corvettes have a threaded antenna and did they have the grounding plate for the antenna? A friend of mine doesn't have his and doesn't recall it ever being on it.
    Scott Sims
    Texas Chapter
  • Gene M.
    • April 1, 1985
    • 4233
    Re: 1968 Corvette antenna and ground
    Scott, My early 68 build Nov 67 has a screw in antenna same as in 67. The ball size on the top should give you an idea if you are dealing with an early or late style antenna.
    • Bryan M.
      • April 1, 1999
      • 386
      Scott Sims
      Texas Chapter
      Scott,
      My 68 has the screw in antenna and the ground plate.
      • D S.
        • March 1, 2005
        • 1551
        Thanks, Gene and Bryan.
