Big block clutch recommendations - NCRS Discussion Boards
  • Michael G.
    • January 1, 1997
    • 1251
    Good day all,
    Am soon to make my clutch purchase for '66 427/390 hp. Typically I've used a Hays street/strip but wanted to expand my horizons . The choices are numerous: Luk, Center Force, GM, Zoom on and on. What is needed is one that will hold up behind the torque generated by the big block and one that won't wear out my left foot. Hays has always served me well. Any suggestions/experiences with others? Thanks.
  • Michael B.
    Infrequent User
    • December 10, 2007
    • 10
    Re: Big block clutch recommendations
    good morning mike, I have a center force in my 70 ls-5 and it works great. Only driven about 300 miles in last 1 and a half years. happy motoring mike b.
    • Terry D.
      • May 31, 1987
      • 2698
      I've always had good luck with Luk, both behind big and small blocks. Unless you plan on doing serious abuse to the clutch, they handle the job quite well without breaking your leg. Don'y quote me on this, maybe Joe can shed some light on this, but I was told they supplid the clutches to GM for their factory big blocks. Just my old 2 cents
      • Michael G.
        • January 1, 1997
        • 1251
        Terry,
        Is your Luk behind a bb engine? Recall a part #?
        Mike,
        Recall part # for you Center Force?
        Any other experiences out there....thanks.
          Originally posted by Michael Gill (28614)
          Terry,
          Mike -
          Try www.dialaclutch.com for LuK applications/part numbers.
          • Michael G.
            • January 1, 1997
            • 1251
            Unless I'm missing it, no detail info on clutch specs.
            • David N.
              • June 30, 1991
              • 142
              Michael,
              I have a 427 cid 390 hp and also had a similar problem. I purchased an L-88 clutch and flywheel from a fellow Corvette Club of Michigan member and it has worked just fine. The pedal effort was nowhere near what I expected the HD clutch would take. Not too hard on the left leg.
              David
              • Michael G.
                • January 1, 1997
                • 1251
                David,
                Thanks for the info. What was brand and model # of clutch?
                • Michael M.
                  • February 15, 2007
                  • 455
                  I have a Centeforce Dual Friction clutch behind my L-36 BB. My engine has some internal modifications pushing the HP close to 500. No problem at all for over 5 years and very reasonable pedal effort IMHO.
                  • Joe R.
                    • May 31, 2006
                    • 1822
                    Michael,
                    After doing some searching of the archives I decided on a Luk clutch for my 427 / 425. The part number is 04-049. I ordered it from AutoZone, I have not received it yet.
                    Joe
                    • David N.
                      • June 30, 1991
                      • 142
                      As this was a used GM oem part, I can't tell you any more than it was the same as an L-88.There are others on this discussion board who may have more info.
                      David
                      • Lawrence S.
                        • April 1, 1993
                        • 807
                        I have used 4 LUK clutches, all on small blocks, with no problem. Good pedal...won't kill your leg.
                        I am soon to put a LUK in a BB L-36. I expect good results.
                          • 43290
                          David
                          David-----
                          L-88 used a different clutch, flywheel and bellhousing than most other big blocks. All 1966-74 Corvette big blocks used an 11" clutch with 14" flywheel except L-88, LS-6, and 1969 L-71 with MA-6. L-88 used bellhousing GM #3858403. All others used bellhousing GM #3899621.
                            • 43290
                            Lawrence-----
                            For 1969 thru 1974 all Corvette big blocks (except L-88, LS-6 and 1969 L-71 with MA-6) used the same clutch as 1969-74 small blocks (except ZR-1). Actually, to be 100% accurate, there was a slight difference in the 1969 L-71 clutch versus that used for other 1969-74 big blocks (except L-88, LS-6 and 1969 L-71 with MA-6) and all 1969-74 small blocks (except ZR-1) but the difference was minor and, for all practical purposes, insignificant.
                              • 43290
                              Terry-----
                              I don't think that LUK made the actual original clutches used for 1969-74 Corvettes. In fact, I think that these may have been of GM internal manufacture but I don't know the details (I wish I did). However, I believe that LUK did manufacture the clutches for C4 Corvettes. I do consider that the current LUK replacement clutches for 63-81 Corvettes are equivalent in every way to the original GM clutches.
