Hi
I have repaired my steering box with a steering column Kit from Paragon $440,- so all the "Steering Items" are new.I have used the ST-12 with no problems.But I still have a loose steering in the "outer" positions to the right and left which I can't get away?Some wise people here in Denmark says that it's normal when you have a "Wormshaft" steering
If I try to tight the adj.screw then it will go tight when I go straight ahead.I can see that the "worm" are not so "high" in the beginning and end on the shaft so maybe it have to be a little loose!
The adj.screw are been correct shims so all are correct mounted!!
Please tell me "is it okay" with that play to the right and left"
Its a C1,1959.
Regards Jorn Jarnved
Its a C1,1959.
