Installing 68 BB engine - NCRS Discussion Boards
  • Brandon T.
    • October 23, 2008
    • 872
    I'm installing my engine with the transmission already installed. Will the engine go in with the motor mounts attached to the engine or do I need to remove the motor mounts before I put the engine in ?
  • Steven G.
    • November 17, 2008
    • 348
    Re: Installing 68 BB engine
    You should be o.k. with mounts installed on engine. Steve
    • Brandon T.
      • October 23, 2008
      • 872
      Thanks Steve, I was affraid the mounts my hit when the motor and trying to align with with the pilot shaft.
      • Steven G.
        • November 17, 2008
        • 348
        It's probably a snug fit, using 2 studs off rear block sometimes helps with alignment and never forget to grease the pilot bearing. Good luck ! Steve
