Re: 1972 small block 3991399 to 330813 water pump changeover
Patrick,
Since the water pump was installed on engine assembly at Flint, I suggest you would be better served tracking the water pump casting date against the engine assembly date. That would eleminate the time lag for pulling the engine from stock at St. Louis.
					Patrick,
 and that 2) the 3991399 was used later than the JG currently lists. As Terry noted, we will have to compare engine assembly dates to water pumps.
