Headlights strobing - NCRS Discussion Boards
Headlights strobing
+ More Options
Posts
  • Michael L.
    • July 31, 2005
    • 562
    Headlights strobing
    My headlights worked fine for a while. Now, they start flashing / strobing after a few minutes on. I checked grounds, connections etc. All wiring is new as is switch. I took the fuse off on the switch and all the lights still worked.
    I took the switch out of the dash and turned the lights on and noticed a faint blue spark on the left side contact on the switch. Any idea what could be causing this?
    Mike L
  • Michael L.
    • July 31, 2005
    • 562
    Re: Headlights strobing
    Anybody else had this issue?
    • Dick W.
      • 10483
      Usually that is caused by the voltage regulator. Check the settings and grounds.
      Dick Whittington
      • Michael L.
        • July 31, 2005
        • 562
        I replaced the old reproduction switch with a different vendors part, it actually looks like a better piece with different molding / stamping marks, new dimmer switch and ran my relays. Lights now hold without flickering, switch breakers do not trip and the lights are brighter. Tonight it gets a run for an hour or so to make sure the fix is finished. Now I can cruise Hot August Nights at night
