Rear Compartment Light - NCRS Discussion Boards
  • Les G.
    • December 5, 2008
    • 158
    I put a new bulb in my rear compartment light on my 1970 Roadster. It still does not light are there any tips on trouble shooting this problem?
    Re: Rear Compartment Light
    It's pretty simple to troubleshoot. There's one wire to the lamp socket assy that carries power (always hot) and a second wire that connects to ground.
    The push botton in the top of the switch/socket that the door contacts, makes and breaks the circuit to the lamp. So, remove the lamp, pop the socket/switch out of the rear compartment trim bezel and probe the connecting wires to see whether you're missing power or ground...
    If both are good, either the socket/switch assy or the lamp that's installed in it is defective.
    PS, before pulling the socket/switch to investigate, open the RH storage compartment door (passenger side), remove the upper storage tray that sits above the jack and take a look see at the connecting wires that run to the socket/switch. They may have become disconnected by a prior owner's efforts to remove/install the jack...
    • Martin N.
      • July 30, 2007
      • 594
      OH MY-
      You should see the newest post about ROADSTERS / Convertibles!
      Marty
      • Les G.
        • December 5, 2008
        • 158
        i GOT MY TERMINOLOGY CONFUSED, MY REAR DOME LIGHT IS NOT WORKING. ANY TIPS
