1978 Speedometer Needle Bounce - NCRS Discussion Boards
  • Mike F.
    • April 30, 1987
    • 3
    My speedometer needle was bouncing on the 1978. The car has cruise control so I removed the output cable from the transducer (top cable) and used white grease to lub the inter cable. Well, now it doesn't work at all. I've removed the cable once again and it is not broken, cleaned as much grease off the cable end and blowen out the the output location. The cruise still works fine. Your thoughts?
  • Oliver B.
    • February 1, 1992
    • 556
    Re: 1978 Speedometer Needle Bounce
    As far as I know, grease is "not the best of ideas" in that area.......
    • Mike F.
      • April 30, 1987
      • 3
      Oliver,
      I'm heading to the local auto parts store to get the correct lub. I read some similar problems that others have had and what they used to stop the bouncing. Thanks for the reply!
      • Oliver B.
        • February 1, 1992
        • 556
        Well, it didn't help much, I'm afraid.......
        • Harmon C.
          • August 31, 1994
          • 3228
          The transducers are wearing out or the grease is getting stiff in your year Corvettes and when the friction gets too much the lower cable breaks. This condition will cause the needle to bounce before it breaks the lower cable. You can change the lower cable as I think it is now broken by the extra friction added by the greaseon the upper cable. The lower cable will have a short life and will break again if you don't replace the transducer.
          Lyle
          • Tom R.
            • June 30, 1993
            • 4099
            So you now have a compound problem...the transducer and lower cable. I replaced (rebuilt) my transducer years ago but when I removed it and took it apart (watch the spring), it was so rusty, the rust had turned to powder. They dry out after three decades.
            Tom Russo
            78 SA NCRS 5 Star Bowtie
            78 Pace Car L82 M21
            00 MY/TR/Conv
            • Mike F.
              • April 30, 1987
              • 3
              Needle bounce fixed. The lower cable and transducer was replaced. The transmission cable nylon piece that goes into the input slot on the transducer broke off in the slot, and the output nylon slot was rounded so much that the speedometer cable didn't turn. I beleive that all this happened because the rivits that hold the bracket for the transducer were loose causing movement. They also have been replaced. Thanks for all the reply's and I'm going out for a test drive!
              Mike Fotiades 11365
              1978 SA Top Flight
