1966 amp guage , DOESN'T WORK ????? - NCRS Discussion Boards
  • Paul S.
    • June 30, 1982
    • 359
    Amp Guage On My 66 Did Not Work When I Bought It.i Just Bought A New Repro Guage. Still Doesn't Work. What Should I Check Now ????? Wiring ?( But Where ?)
  • Gene M.
    • April 1, 1985
    • 4233
    Re: 1966 amp guage , DOESN'T WORK ?????
    Paul, I suggest the fire wall harness plug in connector. This connection is most often the problem. The contact prongs may have some slight corrosion that inhibits connection.
    • Paul S.
      • June 30, 1982
      • 359
      Thanks , I'll Check It Out Tonight
      • Randy S.
        • January 1, 2003
        • 586
        Paul,
        Check the archives as there are lots of posts (including mine) regarding this common issue. My 66 has only a modest 1/8" needle deflection no matter what electrical load. I tried to fix it and just live with it now.
        The ammeter is actually a very sensitive voltmeter. Disconnect the plug at the back of the ammeter and check for voltage to ground on each leg. Should have 12 volts. That will tell you if you have an open connection at the firewall connector.
        Also another check ( learned from the archives) is use a AA battery and flash a momentary voltage across the terminals of the ammeter. Just a quick touch as you don't want to ruin the meter and it should deflect the meter. If the needle doesn't move the meter is defective.
        Hope you are more successful than I have been
        Randy
          PS, a 1/2V source will deflect the ammeter to approximately 40A on the scale without the danger of PEGGING the meter like a 1.5V battery is capable of doing...
