Re: Midyear fan color
John -- I offer this '64 specimen of fan assembly # 3770529 for your comments. I believe it is original, off a 8600 VIN range car that was being resto-rodded. I was recipient of a bunch of parts that he no longer needed
6 pics in total; 4 is limit per post, so I'll do a second post with the 2 shots that show "ripples".
The fan was pretty much covered in road dirt and mild overspray of white ? paint. I took a Varsol-soaked rag and rubbed vigorously to expose what I feel is the original paint surface. I have not used any polishing compound, yet I would call the finish on the gloss side of semi-gloss, as others have mentioned.
But the main reason for this post is the paint imperfections; runs and some ripple effects (pics in post #2) which [I'm guessing] might be due to the freshly-dipped fan assembly being subject to an air current (blow drying), and/or the fan was not properly de-oiled prior to paint dipping (or both). Here's where your opinion would be appreciated.
There are some gravity runs; one on the edge of the blade that was thick enough that it chipped partly off, and the underlying metal rusted, over the years.
Two more pics in next post showing ripples (one on front corner of a blade, but mostly on just about the back of every blade).
.6 pics in total; 4 is limit per post, so I'll do a second post with the 2 shots that show "ripples".
