1962-340hp oil pan - NCRS Discussion Boards
1962-340hp oil pan
  • Kent P.
    • April 1, 2005
    • 5
    1962-340hp oil pan
    hi..i am looking for the correct oil pan for my 62-340hp c-1....all i get from the judging manual is ..5qt design with plug in the rear...any help?..thanks kent( 43669)
    • 43289
    Re: 1962-340hp oil pan
    Kent-----
    If that's what the JG says then I think it's incorrect. The 56-62 oil pans have the drain plug on the BOTTOM "CENTER" of the sump, not on the rear of the pan. 1963-74 oil pans had the drain on the bottom rear.
    • Joel T.
      • April 30, 2005
      • 765
      Kent;
      If this is the same as the 1963 340 pan (the experts will chime in on this) they are hard to find... Nobody seems to make a repro and used ones come up on eBay from time to time...
      Good luck,
      Joel
        • 43289
        Originally posted by Joel Talka (43778)
        Kent;
        Good luck,
        Joel
        Joel-----
        1962 and 1963 oil pans were completely different.
        • Loren S.
          • November 1, 2002
          • 172
          • Kent P.
            • April 1, 2005
            • 5
            thanks guys..no i know what one looks like....but wow( the price)!!!!!..have a good day...
            • Edward L.
              • 278
              Originally posted by Loren Smith (38825)
              The ebay pan is correct for the 1962 solid lifter engines.
              • Tom P.
                • April 1, 1980
                • 1828
                My GD Christ!!!!!!!!!!!!!!!!!!!!!!!!
                • Gary C.
                  Administrator
                  • October 1, 1982
                  • 17969
                  Interesting to note that of the 4 - 57's at the Convention; 3 had the later pan with the raised area around the drain plug and 1 had a passenger car pan on it. Didn't get to crawl under neath the 58-62's that were there. Gary....
                  NCRS Texas Chapter
                  https://www.ncrstexas.org/
                  • John N.
                    • February 1, 1975
                    • 451
                    How big a hit would Kent take for the later made GM pan for that car?
                    • Douglas C.
                      • September 30, 1988
                      • 249
                      I'm sure this is a dumb question, but would it be possible to modify a '63 340 hp oil pan by changing the location of the drain plug? Or are there other differences in outward appearance?
                      The picture provided looked similar other than the drain plug position.
                      --Doug (13644)
                        • 43289
                        --Doug (13644)
                        Doug-----
                        First of all, the 63 340 hp pan often sells for at least as much as this one. So, I don't think that modifying one would be practical.
                        Second, and most important, the configuration of the 62 and 63 pans is completely different with respect to just about everything except that both will bolt up to a small block. Among many differences, the 62 pan is a "3 step" whereas the 63 is a "2 step".
                        • Gary C.
                          Administrator
                          • October 1, 1982
                          • 17969
                          John, on 56-7 usually 1 or a couple of points, if it's a later model pan and the only visible difference is the area around the drain plug. Can't speak for 61-2 folks. That would be a good question for Dave Heitzman the 61-2 TL to answer. Gary....
                          NCRS Texas Chapter
                          • Kent P.
                            • April 1, 2005
                            • 5
                            is there another pan out there with a 3 step design that can be modified to be correct....ex: if the oil plug is in a different location ..maybe it can be moved !...thanks again,,,kent
                            • John N.
                              • February 1, 1975
                              • 451
                              Kent
                              GM sold a replacement trap door for the 61-62 Corvette in recent history ( Joe Lucia might say how recent). The pan uses the later-larger front oil seal, but I believe that few if any could spot any difference in a installed pan. The price on these might be lower. It is a three step pan.
                              Regards
