Ralley wheels judging - NCRS Discussion Boards
  • Henry S.
    • April 30, 2005
    • 816
    I've been searching for a set of ralley wheels for the 67 to get it ready for judging. It currently has a set of Western bolt-ons with 1 correct GM starburst and 3 "made in Korea" so I think I need something besides them unless I want to take a big hit in judging. The car has a Dec 28, 66 build date. I have been searching for the "DC" wheels which I believe would be correct for that date. I spoke with a guy up at BG that thought the only wheel that would judged as far as correct code was the spare since the rings and center caps would be on the others. Is that correct? If so what is judged with the 4 on the car? Of course I realize they have to be correct "type" of ralleys, 15 x 6, with correct width/style rings, and correct style caps. Is there anything else? Thanks for any input, Shooter
  • William L.
    • December 1, 1988
    • 944
    Re: Ralley wheels judging
    Harry at B/G this year they gave my spare a good going over.But as far as the DC wheels on the car as long as they look right, I think you will be fine. They did not ask me to remove the trim rings to look for the DC code.
    Bill
    Bill Lacy
    1998 Indy Pacecar
    • Henry S.
      • April 30, 2005
      • 816
      Bill
      Thanks Bill
      • Kevin N.
        • September 30, 2002
        • 88
        henry...try this. at the 2009 tahoe regionals a judge told me to leave my trim rings on because they do the "quarter trick". they were just interested in the spare tire. if it was a non-dot or not. anyways...you take a quarter and see if it passes through any one of the five holes. i just went out to my garage and tried it. the quarter passed through all my correct "dc" wheels and failed to do so on some after-market 6" wheels that i have in the shed and also failed on my regular chevy 7" ralleys. i guess that's alot easier than poping off all the trim rings.
        in garage now...1991 Z07 coupe... ex-garagers...64cp, 65cvt, 66cvt, 66cvt, 66cp, 66B.B.cp, 67cp, 67cp, 67cp, 69B.B.cp, 69cp, 69cp, 69cp, 70cp, 70cp, 70cvt, 71cp, 71LT1cp, 72cp, 72LT1cp, 72cvt, 73L82cp, 73cp, 73L82cp, 74L82cvt, 74cp, 78s.a.cp, 79cp, 84cp, 85cp(twice), 88cp, 89cvt, 91cvt, 96cp, 96LT4cp, 98cvt, 99frc, 00frc, 00cp, 01cvt, 04cvt, 04Z06
        • William L.
          • December 1, 1988
          • 944
          Keven
          That's a neat trick. Quarter cleared my Dc wheels by about an !/8". Don't have any other wheels to try it on.
          Bill
          Bill Lacy
          1998 Indy Pacecar
          • Brian M.
            • February 1, 1997
            • 1838
            Every day I learn something new, (quarter trick) BTW the valve length & cap & wheel weights become part of the equasion.
            • Mike M.
              Director Region V
              • August 31, 1994
              • 1463
              Yo Shooter,
              1-3/8" stems.
              Dill 627 caps.
              Micro weights with Ounces cast on both ends, mounted inboard.
              HaND
              PS: some Judges will read the "DC" throught the stem hole.
              • Henry S.
                • April 30, 2005
                • 816
                HUH, Thanks for the tip Kevin. I'll have to be sure to have a quarter on hand when I go looking for the rallies!!
                • Henry S.
                  • April 30, 2005
                  • 816
                  Originally posted by Mike Murray (25129)
                  Yo Shooter,
                  1-3/8" stems.
                  Dill 627 caps.
                  HaND
                  Thanks Mike I have the Dill 627 caps and 1 3/8" stems, still looking for some correct weights though.
                  • Mike M.
                    Director Region V
                    • August 31, 1994
                    • 1463
                    You're welcome, Henry.
                    I found a few at a local "Old Time" gas station where they just threw the old weights onto a pile. The pile is now gone, so is the station.
                    There have been some surface in the Driveline from time to time.
                    HaND
                    • Mike M.
                      Director Region V
                      • August 31, 1994
                      • 1463
                      Sorry, I should have mentioned earlier.
                      Caution, "Micro" weights are still available, but, the current pieces have the "Metric Equivalent" cast into one end and may be "filed-off" to be passed-off as original, of course, most any Judge would know this.
                      HaND
                        • 15599
                        If I remember the story about wheel weights that was in The Restorer there were seven (or maybe five, I forget the exact number) suppliers of wheel weights. So just looking for MICRO weights will reduce your chances of success. A look at that story might enlighten you, especially if you judge exterior.
                        • Henry S.
                          • April 30, 2005
                          • 816
                          Terry, do you happen to remember about the time frame the Restorer article was in? I have the Corvette Restorer, 2006 CD version 32.4 but if it came out since then I'll check out the hardcopies. Thanks for the info. Take care, Shooter
                          • Henry S.
                            • April 30, 2005
                            • 816
                            Terry, I did find an article on the CD by Gary Beaupre which is probably the one you're talking about. I couldn't find which Restorer it was, I just did a search of "micro wheel weights" and it brought it up. Maybe Gary or some of the other's that contributed to the article will post and let us know so those that don't have the CD can find it in their Restorer if they need to. Thanks again, now I'll read the article.
                              • 15599
                              I'll get the citation when I get home, but that is the story I was referring to. I still have my Editor's Super Secret Restorer Issue decoder ring.
