67 chassis markings, do I have them all? - NCRS Discussion Boards
  • Chris E.
    • November 3, 2006
    • 1336
    Getting REALLY close to dropping the body on the car (see the thread https://www.forums.ncrs.org/showthre...71156&uid=3126).
    Wondering if this list of chassis marks is complete or not.
    Standing here in MN, chalk and paint at the ready.
    The number before each item references the page in the TIM/JG where it is listed.
    124 Blue and/or yellow on rag joint
    125 Yellow paint on steering box
    125 Blue paint on pitman arm
    126 Staples for A-arm dust shields and the shields themselves are painted black because of the blackout process
    134 Black mitted finish on front stabilizer bar
    134 Orange paint on both front spindles
    136 Starter front plate is natural
    138 Paint the bolts for the bellhousing inspection cover orange
    140 Shim marks in vertical lines
    141 Mitted black finish on mufflers
    145 Gas tank straps are semi-gloss black, while bolts and nuts are zinc
    ??? Calipers had white dabs of paint on them
    ??? Driveshaft has green and orange stripes on it
    Chris Enstrom
    2011 Z06, red/red
  • Mike M.
    Director Region V
    • August 31, 1994
    • 1463
    Re: 67 chassis markings, do I have them all?
    125 - only if the box has a natural finish.
    138 - double check the bolt (cap screw) finish.
    HaND
    • Brian M.
      • February 1, 1997
      • 1842
      I believe that the mitting mentioned in 141 & 134 have been de-bunked.
      • Mike M.
        Director Region V
        • August 31, 1994
        • 1463
        Right, Brian.
        That is a term, not the process.
        Just spray them Flat Black (Blackout).
        HaND
        • Chris E.
          • November 3, 2006
          • 1336
          So............spray the mufflers flat black and DON'T paint the spindles orange? My original spindle was painted orange to some degree, so I'd like to replicate that.
          Chris Enstrom
          2011 Z06, red/red
          • Gene M.
            • April 1, 1985
            • 4233
            [QUOTE=Mike Murray (25129);.............
            HaND[/QUOTE]
            Good point Mike, the 1/4" screws would only be orange if the inspection cover, lower bell housing showed evidence of being covered in orange. This is very variable from full coverage to nothing. The back of the oil pan should also reflect same coverage as this area to look realistic.
