NEED ADVISE, 1970 THERE IS A BLACK WIRE ON THE HORN RELAY EVERY TIME I HOOK IT UP THE BUZZER GOES OFF. REPLACED THE RELAY TODAY SAME THING HAPPENS AC DELCO RELAY. THIS IS WITH THE KEY IN OR OUT OF THE IGNITION. TRIED PLAYING WITH THE KEY A LITTLE BIT AND THE BUZZER STOPPED FOR A SECOND. IS THERE A SWITCH IN THE STEERING COLUMN? WOULD SOME WD-40 FIX THIS? ANY RECOMMENDATIONS.
