Okay, my car's Stereo is the original from 77 - so (by nature) I do not expect modern "high-end sounds". But: it's hard to tune in a clear stereo-signal and even without receiving a good stereo, there is a slight "hissing" to be heard (which gets "worse", in the moments when stereo is received)...
This is the same, be it radio or music from an fm-transmitter hooked to mp3- or CD-player - and that one is lying in the luggage compartment directly below the antenna!
What might be the culprit? Bad grounding? Where - antenna base, maybe?
It's far from being as bad as to justify tearing too many things apart, but maybe it's just an easy one.....
