flat fixer - NCRS Discussion Boards
flat fixer
  • William F.
    • June 9, 2009
    • 1364
    flat fixer
    Is there any good brand of "flat fixer" that can be used without wheel corrosion,etc. to fix a flat on the road rather than using spare?
  • Wayne K.
    • December 1, 1999
    • 1030
    Re: flat fixer
    The ones I've seen are all pretty messy. I would suggest you carry a plug kit and air pump for emergency use.
    Wayne
    • Gary B.
      • September 30, 1987
      • 305
      Re: flat fixer
      Check this out.
      • Dick W.
        • 10483
        Re: flat fixer
        My mind just went blank. It is green, available at Advance, AutoZone, etc. It will not corrode your wheels. Dang, I hate these Senior Moments! I have several bottles of it at the house. I used it in 4 wheelers, tractors, lawn mowers, etc. Works wonders. Just remember if you have a puncture in the shoulder or sidewall of a radial, it is not safe to repair and reuse.
        Dick Whittington
        • Clem Z.
          • January 1, 2006
          • 9427
          Re: flat fixer
          it called "slime"
            • 11692
            Re: flat fixer
            Originally posted by Clem Zahrobsky (45134)
            it called "slime"
            Like this:
