68 Radiator Hose - NCRS Discussion Boards
68 Radiator Hose
  • Charles F.
    • April 30, 2006
    • 99
    68 Radiator Hose
    68, L 36, A/C, 4 speed.
    The top radiator hose is above the height of the top radiator outlet; is this correct or should the hose be shortened ? Supposedly, the hose is a correct repro, but the height issue doesn't look right.
    Thanks.
    Chuck
    • 6950
    Re: 68 Radiator Hose
    Charles, the repo hoses should be the correct length, maybe it needs to be rotated or try switching ends. molded hoses only go one way.also check the part no. on hose to make sure its correct for your application.
