Rocker arms- Clem others - NCRS Discussion Boards
  • John N.
    • February 1, 1975
    • 451
    I need a set of stock type rocker arms for 58. Need brand and part number for good quality set.
    Regards
  • Jim L.
    • September 30, 1979
    • 1816
    Re: Rocker arms- Clem others
    John,
    I use ordinary NAPA/Clevite 214-2081 (1.5:1 ratio) and 214-2129 (1.6:1 ratio) on my vintage racer. Never had a problem. From sampling a hundred or more rockers, I'd say most are made by Pioneer, for what that's worth.
    My spreadsheet indicates that I also bought grooved rocker balls as a separate line item, so the above part numbers may be just the rockers. The rocker balls are Clevite 214-1038.
    All of the above are for 3/8 rocker studs (and I use ARP 300-8241, if that's of any value).
    Jim
    • John N.
      • February 1, 1975
      • 451
      John,
      Jim
      Jim
      Thanks for the part numbers. Can you use !.6 rockers on 50s motors if you don't have guide plates and have not done a slight enlargement of the pushrod holes in the heads. Camshaft is the 097.
      • Jim L.
        • 1816
        I've never tried that, John, so I can't say for sure. It would be an inexpensive experiment to put one 1.6 rocker on and then rotate the engine through one compleat valve cycle, looking for pushrod interference.
        Jim
          • 43247
          Regards
          John-----
          The absolute best quality, most durable STOCK-TYPE rocker arms out there were the Crane Nitro-Carb rockers. If I were using stock-type rockers these are THE ONES I'd want to use. Unfortunately, availability of these "went away" with the Crane Cams shut-down and liquidation. However, with the S&S purchase of Crane assets and inventory, they may "come back" with a "resurrected" Crane. If you don't need them right away, I think I'd be inclined to wait and see.
          • Clem Z.
            • January 1, 2006
            • 9427
            i was told by a GM engineer the durability problem came because the manufacturer went from a 7 step stamping to a 4 step stamping.
              • 43247
              clem-----
              Which rocker arms are you referring to here?
              • Clem Z.
                • January 1, 2006
                • 9427
                clem-----
                GM small bock chevy sold by GM. we had problems with them in race engines where the rules said you had to run production type rocker arms. we ended up hunting up old used GM rockers from junk yard engines to solve the problem. we tried using olds rockers with ball bearing trunnions for ford rockers but the tech inspectors said no go !!
                  • 43247
                  clem-----
                  I assume you mean the non-guided, stock GM rockers. These rockers, last available under GM #3974290, were discontinued from SERVICE in July, 1989 and replaced by GM #10089648. The latter are the guided type rockers and these remain the only available rockers from GM for Gen I and Gen II small blocks.
                  The 3974290 rockers were first used in PRODUCTION in 1969 and were used in PRODUCTION and all 55+ SERVICE until they were replaced by the guided rockers. The previous rocker arm was GM #3843359 used in PRODUCTION for 1963-68 and earlier SERVICE.
                  By the way, 1958-62 originally used rocker GM #3746241 and 55-57 originally used GM #3837175 (yes, that number IS the correct, original number).
                  All of the above are, of course, functionally interchangeable.
                  • Clem Z.
                    • January 1, 2006
                    • 9427
                    clem-----
                    this all happened more than 15 years ago as i have been retired that long
                    • Jerry G.
                      • April 1, 1985
                      • 1022
                      i've been doing a LOT of work on "stock" rockers for the race car and i agree the nitrated, nitro carb units last the best. They made it one whole weekend. If you are will to go with stock replacement the crane roller tip rockers are much better. and will bolt right in.
