How to identify Original 1969 Rear Spring - NCRS Discussion Boards
  • Steven H.
    • June 29, 2009
    • 137
    Re: How to identify Original 1969 Rear Spring
    Dunno, mine sits up fairly well as it is.
    The composite has to be better performance; I don't think that's an issue.
    • Michael W.
      • April 1, 1997
      • 4290
      I see you read a lot of posts over on CF- keep in mind that anything that GM engineered can easily be outdone by somebody sitting under a shade tree.
      • Steven H.
        • June 29, 2009
        • 137
        #18
        The reverse of that is true as well; I've seen many things no one can make as well as GM.
        • John M.
          • November 10, 2008
          • 364
          #19
          I think he's being facetious.
          I think.
          • Steven H.
            • June 29, 2009
            • 137
            #20
            Maybe I was as well
            • Michael W.
              • April 1, 1997
              • 4290
              #21
              I think.
              Yes I was. Very few aftermarket parts (the composite spring included) has been thought through completely from a systems point of view. Again read the stuff over on CF with guys trying to get their car to ride and handle properly.
              • Steven H.
                • June 29, 2009
                • 137
                #22
                Anyone know how much a stock 69 spring weighs?
                I'm going to guess in the ball park of 75 pounds?
                  • 11643
                  #23
                  The previous owner of my 72 had the rear spring replaced because he thought the back of the car sat too low. 3-4 years later I bought the car and thankfully was able to retrieve the original spring from his mechanic's "junk pile" just days before he moved. I reinstalled it and it has been perfect since then. Car had 57000 miles on at the time.
                  The car definitely sat too high with the repro. With the original back in place it sits perfectly - and the previous owner now agrees.
                  FYI, I'd love to debate why you think this is true:
                  "My car will never be point judged. A high caliber detailed driver. Restored with correct detail, but with enough reproduction parts to make judging unrealistic."
                  However, I know that wasn't the point of your thread so I'll leave it alone. I just want you to think about that sentence.
                  Patrick
                  • John M.
                    • November 10, 2008
                    • 364
                    #24
                    Coincidentally, I've been giving that some thought since I posted that statement.
                    My car is relatively original with all of its correct pulleys, brackets, Fan, fan clutch, block, heads, intake, carb, radiator etc. Most of the interior is original as it was a 57000 mile car.
                    The smog and shielding was missing as well as the horns and headlight bucket switches. Everything I replaced was from Paragon and I've tried to remain true with regards to correct head markings etc. The Smog was cobbled together with a 71 pump and a reclocked Diverter Valve with the rest reproduction. All of the suspension components were purchased from Bairs which are likely true to form, but likely deducts on originality.
                    I had no choice but to convert to side exhaust. What's the point of having a Black 69 without Redlines, Louver trim and side pipes?
                    I wouldn't mind trying for a second flight or something similar and could possibly do so with some work. I may have to judge once and correct, but I guess its possible.
                    Maybe I'm over estimating the difficulty in scoring.
                    I'd be estatic with a second flight.
                    • Jim C.
                      • April 1, 2006
                      • 290
                      #25
                      John,
                      I know not everyone in the Corvette world is an absolute purest. I would love to say that every part on my car is original to the car, but that's simply not true. When possible, I would ALWAYS opt for restoring the original part and putting it back on the car. If I couldn't restore the original, then I'd try to go for an original, correctly date coded (if the part had a date code), correctly configured part. If I couldn't find that, then I'd go with the best repro I could find, with the thought of continuing to search for an original that I could restore. I currently have several repro parts on my car. I'm always looking for original parts to replace them with.
                      You have your ORIGINAL spring!!! Restore it and put it back under your car. Of course you're not obligated to follow the NCRS motto, but I think it says something like, "Dedicated to the preservation and restoration etc. etc. etc." You get the point. Put the original spring back on the car.
                      By the way, I know a guy who essentially rebuilt a 1965 Corvette from the ground up using TONS of repro parts. He got Top Flight with no problem.
                      Happy and safe driving.
                      Jim C.
                      • John M.
                        • November 10, 2008
                        • 364
                        #26
                        I agree the original Spring is a no brainer... I just needed help working through the thought process.
                        Thanks.
                        • Steven H.
                          • June 29, 2009
                          • 137
                          #27
                          Since I took the pics; thought I would post them in here.
                          • Michael W.
                            • April 1, 1997
                            • 4290
                            #28
                            Probably so, but another function of judging is to learn about the car, gaining bits and pieces of info that owners may not be aware of.
                            • John M.
                              • November 10, 2008
                              • 364
                              #29
                              That looks very salvagable. You have a nice clean start as well. Mine was a 57,000 mile car and amazingly, every bolt simply cracked loose in the rear with a 3/8" ratchet.
                              Except the large differential bracket which required an 8' breaker bar.
                              Enjoy yourself when you get to that point, especially when the breaker bar pops off when you have full body weight on it
                              • John M.
                                • November 10, 2008
                                • 364
                                #30
                                I'm sure I'll have a 3 page list.
