C1 speedometer Trivia - NCRS Discussion Boards
  • Roy B.
    • February 1, 1975
    • 7044
    I see C&C saying the 53 to 57 speedometer cables are any where from 62 to 68 inch. Long and other e-bay sellers selling NOS cable for 53 to 57 say the same thing .So first lets see what's correct!
    1. As I posted early the cable housing raping shows dark and light coils , where most repro's don't but is all the same color .
    2. The original inner cable is 63 1/2 long for all 53 to 57 Corvette
    So if your looking to locate the inner cable the NOS original is #1562669 you need as shown . Yes it's does fit other makes of cars but this is the one you need if you have the original housing.
  • Steven B.
    • June 30, 1982
    • 4016
    Re: C1 speedometer Trivia
    Thanks Roy!
    Do you know when the cable in the picture was manufactured? I see it has lube instruction on the packaging.
    Steve
    • Roy B.
      • February 1, 1975
      • 7044
      It must be from the 50's no date on it but the grease is
      (AC lubricant Type No. ST-640 is recommented ) grease lower two-thirds of the cable ONLY to avoid grease working up into speedometer. DO NOT OVERGREASE . This will insure quiet operation and long life. Be sure casing is free from sharp bends or kinks.
      That's what it says.
