68 Rear View Mirror - NCRS Discussion Boards
68 Rear View Mirror
+ More Options
Posts
  • Jeffrey A.
    • October 22, 2006
    • 273
    68 Rear View Mirror
    My 68 is without a rear view mirror and in searching for the correct mirror the JD book is very clear in the size,shape and trim color, but there is no mention of date code on the glass, for example 12 DMI 7... Can give me advise on for the are date codes on the glass as I look for one or does anyone have a picture of a original one they could post. I research the achieves and did not see any postings on date codes on the mirror. Thanks - Jeff
  • Joe R.
    • July 31, 1976
    • 4551
    Re: 68 Rear View Mirror
    Jeff,
    You are not going to put the 68 mirror on your avatar, are you? Just a joke.
    The mirror for your car is the same from 67 thru 72. No date code. Just a mirror with stainless steel back and gray rubber around the outside. Day/night and just as simple as that.
    Great repos available from any vendor.
    JR
    • Jeffrey A.
      • October 22, 2006
      • 273
      Joe:
      Good one. Thanks for the info. I just wanted to double back to make sure. It interesting why GM date coded the side drivers mirrors and not the interior one. Thanks again - Jeff
