Original Brass Washer Fluid Filter vs. Replacement - NCRS Discussion Boards
  • Pat M.
    • April 1, 2006
    • 1579
    After reading the recent thread on the original brass washer fluid screen I found one and compared it to the service replacement I was using. You'll notice that not only is the screen different, but the diameter of the plastic rim around the screen is thicker on the original when looking at the screen, and yet the original rim is thinner when viewing the filter from the side.
    There's also wording only on the replacement, "Hebron, Ill. NFC", and the inside neck of the replacement is grooved almost like it's rifled. You can just about make out these grooves in the first picture.
    So even if you simply replaced the screen on a current service replacement, an educated enthusiast could still tell it was not original.
    Just in case anal-retentive minds like mine (might) want to know!
  • Steve B.
    • March 1, 2002
    • 1191
    Re: Original Brass Washer Fluid Filter vs. Replacement
    Pat, thanks for the info, the insanity and the unobtainable pursuit of perfection continues
    • Pat M.
      • April 1, 2006
      • 1579
      Just tryin' to do my part to contribute to our collective madness!
        • 3416
        Hi Pat,
        I believe that Richard Fortier (#82) has been having a little ad in THE DRIVELINE that states he's reproducing the screen for sale for a couple of $$.
        Have you tried one of his?
        • Pat M.
          • April 1, 2006
          • 1579
          Hi Alan. No, I haven't seen Richard's screen. In fact I didn't know he was repoing these until I read it in the other recent thread on this subject.
          • Ron N.
            • August 18, 2008
            • 243
            Paragon also has brass screens $12.00 vs. $3.00 for npn brass.
            Ron
