Thread repair - NCRS Discussion Boards
Thread repair
  • Bob I.
    • November 9, 2006
    • 265
    Thread repair
    Need to repair stripped bolt holes in the frame, for the fuel line clips. Any suggestions on repair, so that the original bolt size can be used.
    Bob
  • Ernie F.
    • March 31, 1975
    • 107
    Re: Thread repair
    Bob,
    I think I responded on your other forum post. I typically would weld up the hole only a tiny amount. If you do this creatively you will be able to screw the old bolt back in with no problems.
    There are other ways to do this from putting fiberglass in the hole, to using expansion plugs but for me the only right way is weld it.
    Ernie
    • John M.
      • November 10, 2008
      • 364
      Re: Thread repair
      Another option if you want a quick and easy fix is to fill it smooth with JB Weld, and drill and tap another hole right next to it.
      The clip will cover the original hole if you get close enough, and you'd be done quicker than it takes to hook up the welder.
      I agree welding and re-threading is the right way to fix it though.
      But on a fuel line clip hidden under the frame, I confess I'd probably take the easy short-cut with either that, or a heli-coil thread repair kit.
      • Jack C.
        • September 30, 1992
        • 1090
        Re: Thread repair
        Try Permatex "Stripped Thread Repair Kit"
        Jack Corso
        1972 Elkhart Green LT-1 Coupe 43,200 miles
        Top Flight 1994, 2018 & 2021
        • Chuck S.
          • April 1, 1992
          • 4668
          Re: Thread repair
          Since the fuel line and brake line clips are secured by self-tapping screws into just the thickness of the frame material, helicoil and other methods of repairing other female threads will not work.
          Anything that reduces the size of the "threaded" hole will work (paperclips have been used for door panel screw holes), but the best permanent solution is weld material deposited on the edge of the hole as Ernie suggested. In my opinion, it doesn't have to be around the full perimeter, just a "tack" at one location will probably be enough. Just be sure the "heat" of your welder is set low enough to melt and deposit material rather than burning the hole larger.
          • John M.
            • November 10, 2008
            • 364
            Re: Thread repair
            My "pull handle" on my passenger door panel is stripped. I haven't got that far yet, but I think I found my fix.
            JB Weld is also drill and tappable. (I love that stuff)
            • Randy R.
              • March 1, 1983
              • 477
              Re: Thread repair
              Try a threaded insert like the Harbor Freight item 1210-6VGA.
              Randy
              • Bob I.
                • November 9, 2006
                • 265
                Re: Thread repair
                I think the welding process is the way to go. Thanks for the advice. I have a mock up,to practice on.
                Bob
                • Timothy B.
                  • April 30, 1983
                  • 5203
                  Re: Thread repair
                  The harbor freight tool mentioned will only repair up to 1/4" size and these frame holes are 5/16", I am not sure they have a tool to go larger.
                  Riv-nuts have been mentioned before on the D/B as I need to get some myself.
                  • Erv M.
                    • February 21, 2007
                    • 445
                    Re: Thread repair
                    I have used the thread repair kits in the past and they are magical. Basically has two gels. Firstgel is put into the hole to fill in existing threads then coat your bolt with a releasing agent and screw in. It molds new threads and when probably setup you just unscrew the bolt. Works great for low torque requirements.
