Correct Color / Finish Questions - Brakes & Driveshafts - NCRS Discussion Boards
  • Jeff H.
    • September 30, 1988
    • 53
    I'm in the midst of a "frame off" on a '64, and need the correct color / finish for the brake drums and the anti-vibration springs wrapped around the drums? Also, what is the correct color / finish for the driveline and rear half-shafts? Were there paint ident. daubs, stripes or rings on these parts? If so, what colors, size and location? Thanks.
  • Dan H.
    • July 31, 1977
    • 1369
    Re: Correct Color / Finish Questions - Brakes & Driveshafts
    Hi Jeff, lots of info in archives about this, but in a nut shell, the rear end, half shafts, brake assemblies with emergency cables were all painted as a sub assembly prior to being installed in the chassis. BLACK is about all you'll see.
    Dan
    1964 Red FI Coupe, DUNTOV '09
    • Alan D.
      • January 1, 2005
      • 2046
      Dan Correc! However take caution with that action! Judges seem to expect no paint on rear end or half shafts. My half shafts cleaned up so nice just did not want to paint so lost points for black rear end, now everything is back to normal - all black.
      The JG on page 146 does say "Evidence of blackout paint is not unusual on all rear suspension components. . ."
      If it is blackout now I would redo it the same - if natural do that.
      • Gene M.
        • April 1, 1985
        • 4232
        Jeff,
        If you want your 64 to look original the black was sprayed on the chassis as an assembly complete. The separate finishes are not detailed as in later mid years. Black paint is typical one sided not too complete in coverage with runs and drips. You may not be pleased with the look of a true, correct 63-64 chassis restoration.
        • Michael H.
          • January 29, 2008
          • 7477
          Dan
          How refreshing it is to see that at least some/most of the 63-64 guys now understand/agree that the differential, drive and control arm/brake assy's on 63-64's were coated with chassis black before being installed on the chassis.
          I think the JG recognizes this now too.
          • Ernie F.
            • March 31, 1975
            • 107
            About time!
            Would you call it chassis black or just black goop?
            I never got a good definition on this. Here are some pics from the frame we did last year.
            Note the location of the marks on the gear box.
            Here is the shock bolts after we removed them.
            In this picture you can see where it ran on the shaft. The clean areas were covered with this stuff, the rusted areas were raw.
            Would I restore one this way? Well I didn’t at the customer’s request.
            I really don’t know how I would do it if it were my car. On one hand I wanted to do it, on the other I thought the frame just looked way to nice to put this stuff on it. Glad it was not my choice.
            E
            • Michael H.
              • January 29, 2008
              • 7477
              Originally posted by Ernie Fry (224)
              About time!
              E
              Well Ernie, looks like everyone agrees with the near complete coverage of black on the rear susp and drive components. Now we're getting somewhere.
