can anyone help me.. stamping tool - NCRS Discussion Boards
  • Steven B.
    • December 10, 2007
    • 1
    can anyone help me
    sent my1966/425 hp big block to the the mechine shop to be re bilt thay told me that the motor
    needed to be deched ok but when i got back my numbers were gone.......... and not shor what my number was.
    i think it was TO1227 IP 6112092 can anyone tell me if this is right?
    ENGINE NUMBERS 427 CIC 425 HP DEC, 1966 RALLY RED
    CAR SERIAL # 194676S 112092
    BLOCK CASTING # 3869942
    BLOCK SERIAL ON PAD #---------------
    BLOCK CODE # J 19 5= October 19-1965 ( think it's a J ) ill have to look again
    ENGINE SUFFIX CODE # IP
    can anyone tell me were i can get a stamping tool to rent ? or is there someone in the try stste that can do it for me? new york
    vett2000sb@aol.com Steve B
  • Jeff D.
    • April 30, 1995
    • 95
    Re: can anyone help me.. stamping tool
    Ed Korte from "numbers match" has the tools and stamps you need. He has an ad in the driveline. His number is 520-544-9209. I have used him before and he can help you with the assembly numbers as well. Hope this helps. Jeff
    • John M.
      • November 10, 2008
      • 364
      If your engine was matching numbers and original to the car, your builder just cost you over $20K + in value to the car.
      A restamped block will certainly be noticed by an educated buyer.
      Even if it wasn't original to the car they significantly impacted the value of the engine in and of itself.
      That's a shame.
        • 11668
        This is not a job I would do myself if I had any interest in "getting it right."
        Seriously consider having the engine shop pay to have this damage "fixed" by a professional. There are a few people out there who can resurface the block, stamp the numbers, and end up with a very satisfactory result.
        If you just want "numbers" is a whole different thing than if you want it done right.
        • Clem Z.
          • January 1, 2006
          • 9427
          doc you mean there are people out there in the hobby that would do that,i am shocked,shocked i tell you.
            • 11668
            Hard to believe it, eh?
            • John M.
              • November 10, 2008
              • 364
              Aside from the ethical questions it raises, it's a science in and of itself with correct broach marks (which are difficult to reproduce), Correct Fonts, typical wear on frequently used characters, Gang Stamp evidence in both angle alignment and depth of strike, and anomolies evident within both the engine assembly Plant, and final assembly plant.
              I'd hold the Engine builder responsible as well except for the minor detail that they told you it needed to be decked before hand.
              Legally they wouldn't be negligable.
              Personally, I would have the builder sign an affidavit stating what happened with notorization before I re-stamped it.
              Once the numbers are gone, there will always be a shadow of doubt cast on its originality.
              Restamping it will solidify the doubt.
              (personal opinion)
              Good Luck with whatever you choose.
              • Tim E.
                • April 1, 1993
                • 360
                There are a couple engine block supply companies that advertise in Hemmings Motor News that offer stamping services and rent stamping tools. I don't have any experience with them, but have seen their ads. Look under the "Corvette Parts" section. Tim
                • Michael W.
                  • April 1, 1997
                  • 4290
                  Presumably the broach marks are gone, taking the stamped characters with it. Restamping just the alpha numeric data without having a typical pad surface would look worse than a completely blank pad.
                  Even if it was re-broached and restamped, a comparison with original cars made just before and just after yours will reveal this as a 'suspect' engine.
                  Leave it alone, and go after the engine shop for compensation.
                  • Ronald R.
                    • May 31, 1989
                    • 671
                    Just
                    FYI I did a 66 BB car for a friend and the block need decked. My friend decked the block but left the pad untouched. With the head on it is not detectble.
                    RDR
                    • Kenneth H.
                      • October 27, 2008
                      • 500
                      Steve,
                      Do you have any pictures of the pad before it was decked? When I purchased my LT1 last year, the first thing I did was take a couple hundred pictures of it from all angles including the engine bay, chassis, interior, exterior, pad, trim tag, cert label, etc. If you did, and you get a certified doc from the mechanic, it might just help some at resale.
